Home/ Questions/Q 6349
Next
bhumitboraniya
  • 5
bhumitboraniyaBegginer
Asked: June 20, 20232023-06-20T13:02:06+05:30 2023-06-20T13:02:06+05:30In: Android Development
how to set onClickListener for Drawable Right of an EditText
  • 5
I have two events on EditText:
  1. Enter Password in EditText
  2. Eye Button in Drawable Right for Hide or Unhide The Password Text
androidandroid developmentandroid studioedittextjavaxml
  • 437 Views
  • 0 Followers
  • Voted
  • Oldest
  • Recent
  • Random
  1. Aryan Atel Begginer
    2023-06-20T15:44:25+05:30Added an answer on June 20, 2023 at 3:44 pm
    The first thing you have to do is give the drawable an ID and get its reference in its respective java file, and after that, you have to setOnClickListner on it and implement two methods.
    drawableID.setOnClickListener(new View.OnClickListener() {
                @Override
                public void onClick(View v) {
            yourEditText.setTransformationMethod(null);
    // To show password
    And In Xml ofEditText set android:inputType="numberPassword"
    • Reply
    • Share
      • Share on Facebook
      • Share on Twitter
      • Share on LinkedIn
      • Share on WhatsApp
  2. Mohammed aleem hasan
    2023-06-23T16:35:54+05:30Added an answer on June 23, 2023 at 4:35 pm
    To set an OnClickListener for the drawable on the right side of an EditText, you can follow these steps:
    1. In your XML layout file, define the EditText and set the drawableRight attribute to the drawable you want to have clickable:
    xmlCopy code
    <EditText
    android:id="@+id/editText"
    android:layout_width="match_parent"
    android:layout_height="wrap_content"
    android:drawableRight="@drawable/my_drawable" />
    1. In your Java or Kotlin code, find the EditText view and set the OnClickListener on its drawableRight:
    javaCopy code
    EditText editText = findViewById(R.id.editText);
    editText.setOnTouchListener(new View.OnTouchListener() {
    @Override
    public boolean onTouch(View v, MotionEvent event) {
    final int DRAWABLE_RIGHT = 2;
    if (event.getAction() == MotionEvent.ACTION_UP) {
    if (event.getRawX() >= (editText.getRight() - editText.getCompoundDrawables()[DRAWABLE_RIGHT].getBounds().width())) {
    // Click event on drawableRight
    // Perform your desired action here
    return true; // Consumes the touch event
    return false;
    Note: The code above uses an OnTouchListener to detect the touch event on the drawable. It checks if the touch event occurred within the bounds of the drawable on the right side (drawableRight). If it did, you can perform the desired action. Returning true from the OnTouchListener indicates that the touch event has been consumed and should not be propagated further.
    Remember to replace @drawable/my_drawable with the actual drawable resource you want to use.
    If you’re using Kotlin, the code will be similar, but with a few syntax differences. Here’s the Kotlin equivalent:
    kotlinCopy code
    val editText = findViewById<EditText>(R.id.editText)
    editText.setOnTouchListener { v, event ->
    val DRAWABLE_RIGHT = 2
    if (event.action == MotionEvent.ACTION_UP) {
    if (event.rawX >= (editText.right - editText.compoundDrawables[DRAWABLE_RIGHT].bounds.width())) {
    return@setOnTouchListener true // Consumes the touch event
    false
    By implementing the OnClickListener for the drawable right of the EditText, you can respond to clicks specifically on that drawable and execute your desired code accordingly.
    xml
    Copy code
    <EditText
    android:id=”@+id/editText”
    android:layout_width=”match_parent”
    android:layout_height=”wrap_content”
    android:drawableRight=”@drawable/my_drawable” />
    java
    Copy code
    @Override
    if (event.getRawX() >= (editText.getRight() – editText.getCompoundDrawables()[DRAWABLE_RIGHT].getBounds().width())) {
    return false;
    kotlin
    Copy code
    if (event.rawX >= (editText.right – editText.compoundDrawables[DRAWABLE_RIGHT].bounds.width())) {
    false
    • Reply
    • Share
      • Share on Facebook
      • Share on Twitter
      • Share on LinkedIn
      • Share on WhatsApp
Leave an answer
Cancel reply
You must login to add an answer.
    Jova0731 added an answer Before I logged in I checked out Big Ass Sex… October 8, 2025 at 11:41 am
Related Questions
  • LushKite
    How to Make Ganganzelli Trulala in Steal A Brainrot
    • 0 Answers
  • jean8
    u4gm Diablo 4 Season 10 Rogue Build for Efficient Farming
    • 0 Answers
  • Anonymous
    The Art of Escalation: How to Survive and Thrive in ...
    • 0 Answers
akshatt25
akshatt25
  • 12 Questions
Insert/edit link
Enter the destination URL
Or link to existing content
    No search term specified. Showing recent items. Search or use up and down arrow keys to select an item.
